Looking at Hifonics AMPs please add your .02...
Defiler
Here is my current setup:
Infinity Kappa 4.5" seperates in front
Infinity Kappa 6.5" in rear
Infinity Kappa 10" 4Ohm Sub in boot
Crunch V-Drive 600.4
Crunch V-Drive 150.2 bridged mono @ 250W
Pioneer 4300 HU
Computer for MP3s, DVD, GPS, blah blah blah
I was very happy with the sound this setup produced but my 4 ch. AMP is dying after 3 years of use and I need a new set of AMPs. Yes I need two because I'm OCD about certain things and this is one of them. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I know Crunch amps are over rated and I am getting rid of the head unit and going with a Clarion EQS560 Pre-amp Equalizer so I can go right from the computer to the EQ to the amps. The EQ claims 7 Volt output which puts the Pioneers 2 volts to shame and should produce a cleaner signal and require less gain on the amps while producing the same results (please correct me if I am wrong on that last staement).
So, I have about $450, give or take, to spend on 2 amps (1 4 ch. and 1 2 ch.) and I was looking at the Hifonics stuff but was wondering if I should look at other lines. I know the Kappas don't require a lot of power to sound good and the sub is rated at 275W RMS and I think 1000W Peak??? All the infinitys are the green ones.
Any input you guys can offer would, hopefully, be a big help. Thanks.
Defiler
Defiler
Tampa, FL.
limitkid7
