Look What I Bought Today!!!!
brchd
Banned
JL 1000/1 and 300/2 from Ultimate Audio in Orlando....cost me a pretty penny.//content.invisioncic.com/y282845/emoticons/blackeye.gif.66a1670f5aaf7f406e783a63e3387dc5.gif
can't wait to hook it all up.....CMON buy my other amps!!!//content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif
just tired of the DA. wanted something with a higher damping factor. plus DA customer service SUCKS ***! I'm not even using the DA to its full potential(2 ohms=750wrms)
Fair enough.
Though I do not think the difference in damping factor between the D6 and the JL is going to make as much audible difference (if any) as you might think....
I'm in the same boat as you as far as only using "half" the amp. My single 12" is a D4 as well. //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
eventually i'm gonna run 2 L7D4 10's @ 4 ohm. temporarily i'll be running 1 10" L7 dual 4 ohm at 8 ohms....the JL tech said the amp will only do "about"500 watts @ 8 ohms.....I dont think i should dump 1kw on a single L7 10....they only handle 600wrms.
You better be running L7 at 2 ohm right now. You may find it strange, but high impedances is not good for these amps with regulated power supply. Just set the gain right, and use common sense with volume control //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Hope that they last you more than a year or two before dying. Much better quality and performance to be had out there.
whats that mean? JL are not reliable?
also, I am very good friends with the manager at the West 50/Pine Hills rd shop....
BTW i spoke with JL tech services and they said i would have NO problems running it at higher ohm loads....
brchd
Banned
brchd
WOC
Prowler573
