Look look! I can cut out a circle!!!
flakko
Veteran (my butt)
10,845
So Cal
i made a resolution when i turned 20.... to make better boxes hehe.
it aint perfect, but its progress //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
yup! every box i make i get better and better. only if i had a table saw... //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
JAJAJAJAAAAAAAAAAAAAAAAAAJAJAJAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA!
Still got some gaps... but better than te original ****...
nG
no leakes! put it up to a light!
i mean compared to this:
prettty dang good no?
of cuz! 10 dollaz xtra for a normal circle //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
it is it is! Eldorado, JAZN and i (actually just eldorado) ran the box over with his burban hehe.
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
112
If you buy a replacement OEM Radio Harness the colors will match up then you can use a wiring harness to connect to that. According to a few...
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
If I was in your situation, I would experiment with the wring for a day or two. If that didn't work, I would purchase an external amplifier. Run...
Yeah well im a maintenance technician working 12 hr days 6 days a wk ontop of school 3 times a wk which are 4 hrs long .so ya an hr drive is hard...
flakko
Veteran (my butt)
flakko
So Cal
Eldorado
    May 18, 2024
    May 18, 2024
