look at this beast!!!
Valid point, no reason why he shouldn't have them readily available. I believe he has even mentioned in his forum that he has a DATS, so he could at least give us some quick ballpark figures.
I'm not going to lie, this is news to me. I have FEMM installed on my PC as well, and I am not aware of it being built with the ability to spit out complete T/S parameters. It will obviously give you BL^2/Re, but I do not see how it could provide a whole list of T/S parameters (ex. how would FEMM calculate Cms or Vas?)
My FEM software package includes all of the latter complete with T/S specs because that [woofer design - Cms/Vas/etc] is included. Pretty critical parameters when designing a speaker. So he is designing a speaker without those critical parameters?
As mentioned in my post you quoted, it does not look like he has uploaded any FEMM models using the SPL coil. I would assume the model he is showing is with the daily coil. However, I do agree 100% that this is all speculation until he comes back and provides an answer for these questions.
Hopefully he comes back soon to provide further clarification //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
As of this post I have yet to see a simple T/S list.
The FEMM model above is the daily coil. As previously stated the SPL coil will not be used due to induction so there is no need to have it Klippeled
"Induction" [i'm assuming your term 'induction' to be severely high inductance] does not negate it for measurement by Klippel. Klippel can still measure various forms of THD, Xmax, Xsus, Le in a three dimensional realm, etc. It is very solid measurement of a loudspeaker and it [Klippel] should not be ignored because a driver has very high inductance. Why would you not send the woofer to be Klippel tested? If it has high inductace, it has high inductance [read: limited bandwidth and slow transient response].
I do not publish small signal parameters as they are not an accurate representation of a driver under power.
Ok. If, by why what you said above, an accurate representation of a driver under power can not be defined by T/S figures then an "accurate representation of a driver under power" CAN AND IS defined by Klippel measurement (as Klippel is performed under power).
Are we even talking about the same program? When I say FEMM I'm talking about this specific program which is a free 2D magnetics FEA program.
Quentin has and also uses SpeaD and Reverse SpeaD (not free and made available from Redrock Acoustics). I can only assume he used FEMM to design the motor as maybe SpeaD can't design a MMAG motor (I have not played with SpeaD yet so I can't confirm this).
I'm not on your side and I'm not on the Quentin's side, but I've read through his forum and with his Ethos and the people he works with I will at least give him the benefit of the doubt for a bit until he has a chance to expain or provide proof for his claims.
Why would I not waste the time and money to send a high inductance SPL sub for Klippel testing? Because it has high inductance. I assume you already know the reason since you are associated with Jacob and you just trying to test me. But anywho I'll try to explain in laymen's terms.
VERY simple concept. A coil is an induction coil exactly like a coil in a crossover network. And what does and induction coil do? it limits highend frequency going to a driver. Same exact thing happens on a transducer however unlike the coil being an air core coil it is turned into an iron core which increases this effect even more. Why is this a bad thing especially in a SPL driver? Simple.
It's a spl driver so you are going to be playing 50, 60, 70 hertz burps or short runs. The I had the SPL coil built as it would handle gobs of thermal abuse however its "crossover" effect brought it down almost 6 db at 70 hertz. How do you test for something like this? Very simple. Burp a sub stage in a vehicle at 70 hertz and measure the output with a term lab. Then put the SPL coil in line with the sub in the vehicle and readjust amp gains (ohm load changed) to achieve same power then remeasure and record results. What you have done in put a filter inline with the driver and measure the high pass roll off that has been caused just like in a crossover used in a set of components. Why does this matter in SPL? Again simple.
Since we now know the SPL coil will be down 6 db at 70 hertz we can figure out how much power needed to achieve the same SPL. Most everyone knows in order to gain 3 db you need to double your input power. Lets say the daily coil will do 150 db on 3,000 watt burp (numbers are arbitrary). Now remember the spl coil is down 6 db at 70 hertz (which is a typical burp realm). This means the spl coil will hit 144 db on the same power at 70 hertz. To get to 147 db (remember on paper you need to double power to gain 3db on paper) the spl coil will need 6,000 watts, and it's still 3 db down. And to get to 150 db it still needs to gain ANOTHER 3db so power needs to be doubled again. So, 12,000 watts is needed just to achieve the same output. Now I'm not a competitor but I'd rather only need 3k versus 12k to achieve the same output.
Yes, Klippel does measure under power and it is called LSI or large signal Identification and it's what I publish as specs. (see Ethos parameters) And you don't NEED to measure with the Klippel to get a ballpark idea of what it will look like if you already know the parameter shifts of your softparts. Fs is gonna go down, Vas is gonna go up, and Q is gonna go up.
You do understand that Patrick Turnmire is the CFO of STEP Technologies which is the company that owns the rights to MMAG? This is the guy I use (along with Enrique) for transducer engineering and Klippel testing. And we can assume you use as he is the ONLY independent lab in the US with a Klippel analyzer. If you use his advise in designing why would my techniques be any different?
I think you mean the reverse. Check your facts before you post bile on forums. I design and manufacture low inductance subwoofers for Stereo Integrity, not the other way around.
I have an advanced FEM program (not FEMM as you two have been referencing during this thread) that shows anticipated T/S's as many variables of subwoofer design are able to be changed/manipulated during the design process...which is the only way to design a driver. If you can not change the Vas of the driver, Cms, etc, while designing, then what good is the program? The linearity (or non-linearity, depending on your market) of the soft parts along with the basic fundamentals of design are pretty important when designing a subwoofer. You can have a cool motor but the rest of the speaker matters a good bit. //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
Basically you spent a lot of time not answering anything. You danced around it[everything] instead.
Can you answer the questions I have been asking this entire time?
1) Can you please publish a full T/S sheet in any form (normal and/or SPL configuration)?
2) When have referred to "motor force" are you referring to BL^2/Re?
3) Re: Question #2 ; If you are not referring to BL^2/Re, what are you referring to?
Red Rock Acoustics is not the only Klippel in the USA. Since you have stated the latter you are eluding to you having your woofer tested by an additional Klippel-capable party. I don't care who you used. I only want everyone on here to see the results because, obviously, you have Klippel results [you stating that there is more than one person in the USA that can Klippel woofer -
and yet you are, for some odd reason, unwilling to let those results be public. Your SPL figures/estimates stated above are in theory, not reality. I hope your testing shows results close to reality and I hope that you show your results with us.
I have already said numerous times it has not been Klippeled this is why parameters have not been posted. I don't have clout here like you so I can't just post a number without being nit picked. If you want Klippel results to back published specs on a driver that is in production every Klippel graph on the Ethos is avaliable and have been on SSA since August. You can even find numerous posts there about me not willing to give final specs on the 12 version until LSI was performed. If you want I'll even send you the file I have nothing to hide and no need to dance around.
Again. The Magnetar has NOT been Klippeled therefor no specs are available. While this may be an issue for some manufactures due to them needing to sell preorders therefor they need to publish specs prior to production this is not an issue for me as I don't do preorders. I wait till I actually receive my product before I try to sell it. Again once the time comes when my production run comes in, everything is finalized, and a couple current customers test the product no specs will be published and nothing will be for sale. When that time comes you will have any and all information you like and you can scrutinize it as you like.
garychurch84
garychurch84
hornbeak,tn
garychurch84
