lol attempt at electrical engine with sub magnet
the install only caught on fire from that **** screwdriver i left in the trunk that rolled into the power wire and dragged it to the trunk lid. should i flip a coin to hook this up to the wall socket or to the amp in car? car would be least expensive to have burn down. if i hooked it up to the wall what could be worse case scenario? wire melts like a fuse or would the circuit breaker trip before that? im not real sure about ac power but if 12vdc can make a 4ga wire turn into a neon light idk about the ol wall socket.
ip check? k i finally figured out that even if it did rotate the wires would spin around each other and tangle up in a few spins. not as simple a thing as i first though, gotta find a way to use some sort of berings in it
k i've got to redo the whole thing, im not even sure what kind of motor this would be under. but i decided to take the time to read how the motors work lol.
Hydrastas
Hydrastas
NE ks
Millertime1028
