loc....do i need one?
  • 2
just installed my aftermarket amp to my factory hu using the amps high level inputs. just cant get rid of annoying tapping sound coming through the speakers. ive adjusted gain to no avail. also i have sound on both channels but if i move balance all the way to right side sound dissapears on that side until i move it back to center. ground is good and wires are correct.would a loc fix this and what would be a good one for a 5 channel amp.?
2014 Toyota avalon......it's the non jbl system however it has 9 premium speakers.5 of them are powered by hu alone and the other 4 are powered by a small amp under the seat.the four are what I'm repowering with aftermarket amp.I get amplified music but there is a low static scratch about a sec apart.it does it even with the engine not running.the hi level inputs had a ground wire for each harness that goes to chassis ground.when I hook them up I get alternator whine so I disabled them.would a good pic help?
Yeah tapping off the 4 gauge is typically fine. However, you need to fuse the smaller wire right by the 4 gauge at 1 amp (or whatever the small...
786
Thanks for the link to this video, I've seen this one before but it's not for component speakers which is what I'm going to install and the part...
598
You should run all exact matching subwoofers in one singular enclosure and 1 amp or matching amps for the best listening experience for the space...
There are a couple that SMD has tested, around $20.00 that should take the wattage from most any HU. If you are tapping into the speaker wires...
blumule
blumule
greensboro nc
BCotrell
saints747
    May 7, 2024
saints747
    May 7, 2024
