Loading issues
  • 6
9515ROB
TEAM DTF
2,385
Sherman IL
I have my car walled with 8 10s. It seems the top passenger side and top middle subs have a loading issues because i keep breaking the joint where the cone attaches to the coil. It seems like it is the top passenger side one more than the middle but i replaced the middle one the other week and noticed it is starting to rip its self apart to.
How should i go about with fixing this without building a new baffle.
Here is a pic of my wall. It is before i had the port in so dont say its because i have no port
i dont know about the loading issue other than the top of the box being on a slant causing wave interferance but as far as the neck joint. when u fix it heres the steps for an unbreakable joint
use 5k lbs pressure epoxy on the joint.
let dry
put a line of goop on the bottom of the neck joint (aka spider joint)
let dry 24 hours
put a line of goop on the top of the neck joint (aka cone attachment joint)
let dry 24 hours.
then recone the sub and i promise you wont be able to break that neck joint again. i have had about 10 blown subs and alllll of them were thermal none of my blown subs ever came from mechanical issues.
When you have that many subs in odd shaped boxes with a port so near some subs and so far away from others it causes loading problems. Its just the design of the enclosure.
Be sure to see the sub specs. It should tell you the ideal sealed enclosure size.
602
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
Are your tweeters amplified or powered by the radio or maybe factory amp? I'd check your wiring for sure, make sure 12v power and ground are...
9515ROB
TEAM DTF
9515ROB
Sherman IL
lowriderram_95
    Jun 1, 2024
    May 31, 2024
