1. Product:
Sound Stream XXX-6500D
2. Specs:
FEATURES
• Gunmetal finish w/ brushed accents
• Non-regulated mosfet pwm power supply
• Three-way protection circuitry (thermal, short,
impedance)
• Twin stack technology TM(strap amps together
for double power)
• Delayed on/off circuit
• Variable low pass crossovers
• Variable bass boost
• Variable subsonic filter
• 180 O phase control
• Pre-amp outputs
• Dash mount remote gain control
• Direct wire 4/0 ga. Power, 4 ga. Speaker terminals
XXX-6500D Channels 1 ch. Class D
RMS Power @ 2 Ohm, 14.4V 3,300
RMS Power @ 1 Ohm, 14.4V 5,300
RMS Power @ 1 Ohm, 16V 6,500
Total Harmonic Distortion 5.00%
Frequency Response 15-150Hz
Signal-to-Noise Ratio 80dB
Damping Factor 350
Signal Voltage 500mV-10V
Potential Current Draw 460A
Dimensions: 2.625"h x 11.375"w x 25.75"L
Low Pass Filter 18dB, 50-150Hz
Bass Boost 0-18dB, 45Hz
Subsonic Filter 18dB, 15-40Hz
Phase Control 0-180º
3. Description/Condition:
I have a sound stream xxx-6500D in 9.5/10 condition has a scratch on one side, was installed in my truck but is coming out this weekend for my American Bass 400.1. Works 100% and can even make a short video of it if you would like. The way it's mounted I can get a photo of the scratch it's on the bottom the way it's mounted.
4. Price: :
$700 OBO
5. Pictures:
Scratch is on the other side, it I did not even see it until installing it nothing major really to be honest.
2. Specs:
FEATURES
impedance)
for double power)
• Pre-amp outputs
Damping Factor 350
4. Price: :
$700 OBO
5. Pictures:
