little confused !!
Spddracer
Sounds Goooooood
Ok lets say I have (2) 4 ohm subs SVC , I can either have a 2 or 8 ohm load ,Ill be runing at 2 ohm , I have an amp , Says its output is 100 watts x2 at 1 ohm stereo and 300 watts briged @ 2 ohm , So if I give it a 2ohm load bridged this is what I get correct , Someone please explain this , I guess im confused because Ive heard when you brigde it drop the impedence in half HELP
Originally posted by Jmac When you bridge it, you will have a 2 ohm load ... so, therefore, each speaker will get ~150 watts ...
The amps says 300 watts at 2 ohms briged , Does this mean I can give it a 2 ohm load ? im making sure the amp
can handle it , Soundstream rub 302
if it says 300watts bridged @ 2ohms, yeah it should work.
hmm, i would think that if you bridge it you double the impedance, since you taking both channels, you would just add the impedances. this sounds better than the half impedance thing you said.
Originally posted by Matador if it says 300watts bridged @ 2ohms, yeah it should work.
When you brigde an amp each channel sees half the load , So basicaly yes it drops in half
Still, that amp most likely pushes more than 100 x 2 @ 1 ohm stereo...if it pushes 300w @ 2 ohms mono, then it sits probably actually pushing 150 x 2 @ 1ohm stereo.
But anyway, impedence is only added if you wired the speakers in series. parallel wiring cuts the impedence in half (when you run 2 speakers).
Spddracer
Sounds Goooooood
Spddracer
Ohio
ftgu
