literal A** kicking? please
Its mostly in the install. Most of the kick in your kickdrum is going to come from not the sub but your midbass, which is usually the 6 1/2 driver from a component set, find a set with good midbass already, then give it a good install to get the most from it. Pair that up with a 10" - 15" sub, give it all some good power and it should play ANY music well.
Like jujumantb says, install means a lot on how a sub sounds. Most junk people by at stores is bandpass "cool" looking boxes that sound really bad. A high quality sub in the correct enclosure can do death metal just fine.
My 12a hits double bass perfectly and sounds awesome. It's a good speaker in the correct box.
Pentagon subs play rap best. Squares are best for rock. Round just ***** at everything. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
you forgot triangular subs. Those are well suited for emo music.
702
Check out Sonic Electronix as well. They have some great deals usually and excellent Customer Service also. I like to buy my HUs /Head Units from...
613
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
TeValere
TeValere
washington
HiAmplidude
