Line Output (Hi-Lo) Converter & 5 Channel Amplifier
What about the Audio Control DQL-8? That has LOC capabilities with EQ and probably isn't as expensive as the Audison Bit1. Another problem with the Bit1 is that it is "supposed" to be installed by an authorized dealer.
Can your amp internally make a sub signal. Or does it require RCA in's?
The 4-channel scosche LOC from gaymart will work fine if your amp will make an internal sub signal. I used it with my setup for about a year till I got a headunit.
I can post pics of my old setup if you want.
I can post pics of my old setup of you want.
what he said ^
Honestly something like the Bitone, 3sixty, pxe-h650 or similar is going to be your best bet.
You will get a LOC that will flatten out the factory headunit, give you some EQ 3 ways crossover etc.
Honestly something like the Bitone, 3sixty, pxe-h650 or similar is going to be your best bet.You will get a LOC that will flatten out the factory headunit, give you some EQ 3 ways crossover etc.
The only downside of going with a 3sixty is that RF has been having horrible Blue Tooth issues with that particular unit. A lot of times BT works for the initial install, but later when you go to change something, the BT connection is DEAD!
Slammed
Striking Accord
Slammed
Gotham City, NY
IDSkoT
