line output converter or amp quality?
rklabon
i have 2 12 inch type r's that don't pound like type r's at all..the problem is either i have a pyramid 2700 watt amp which i know is bad quality..or that im using a line output converter and the signal is no good..but i don't know why they dont bump like crazy...if it is the amp i am gonna get the Alpine MRD-M1005 V12 Digital Mono Amplifier
all the connnections are good on it i think it just might be a bad amp...it doesn't even say the rms on it...just the big max ouput numbers...its also a 4 channnel amp bridged down to two subs
Does it look like this?
Four Channel Amplification
4 x 675 Watts MAX Output @ 4 Ohms
2 x 1350 Watts Bridged @ 4 Ohms
Dual Fully Adjustable Electronic Crossovers
Dual Variable Bass Boost: ( 0~12dB @ 60 Hz)
Soft Turn On/Off Circuit
2 Ohm Stereo Stable
Bridgeable Into 4 Ohms
Dual MOSFET PWM Power Supply
Variable Gain Control
Remote Turn On
Remote Bass Boost
Blue Light Illuminated
Heavy Duty Aluminum Alloy Heatsink
Hi/Lo Level Inputs
Gold Plated High Impedance Input
High Level MOLEX Input
Power and Protection LED's
S/N Ratio: >95dB
Frequency Response: 15-30k Hz
THD:
Fully Protected Circuitry
Dimensions: 10.7'W x 2.4'H x 17.7'L
Are your subs dual 2's? Wired in series for 4 ohms each??
Regardless - your amp's rms ratings are -
75x4 at 4 ohms stereo
115x4 at 2 ohms stereo
230x2 bridged.
With 2 20A fuses those power numbers sound reasonable, but for Type R's do do their thing, I'd say power's what you should be most concerned with, not the LOC.
okay...yea a friend from mobil link said the line out converter gives a more crystal signal then rca's from a head unit...but now i guess im not worried about it..just need to find an amp
yea that didn't make sense to me that it could take a signal to speaker convert it to a rca signal and it would be more clear...Kenwood Excelon KAC-X812D thats the amp im looking at
rklabon
rklabon
Wisconsin Rapids
addisdar
