Line Drivers?
Winter_C
Teh Pinto Driver
Can someone explain what a Line Driver actully does? I know this is probably a noob question...but I have never used one, and my buddy has one, just wondering if it'd actully help my system at all if I hooked it up...whats the benefit of them? And are they worth using?
Thanks.
Thanks.
They increase the voltage on your preamp. Lets say your head unit has 2 volt preamp. Well a line driver will boost your signal to 6 volts or more. It allows you to run your gains lower.
If it allows you to run your gains lower, wouldn't that mean it's louder at higher gains?
gain =/= volume
It means you can set the gain lower and still get the same amount of output, go above that (in either case) and you'll clip the signal
Winter_C
Teh Pinto Driver
Winter_C
Mitchell, SD
bubbagumper6
