Line drivers
mine is in the trunk. if anything i think they mean keep the line from the head unit to the line driver as short as possible.. cuz umm if u had a 200 ft RCA going from the head unit to the line driver and mount the unit up by the HU.. ummm.. yea.. you get the idea. and might i suggest the audiocontrol EQX? thats what i have.. an EQ/line driver/crossover in one. and all three are great at what they do. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
why do you need a line driver? if your headunit already has rca outputs there is no need for a line driver. that's why amps have gains //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
well with the xenon amps u have to set the gains almost all the way...some that had the exact same amp got a pg line driver and he didnt have to put the gains all the way up nemore...he only had to put it like mid way...
u think its a waste of money? i have the p80mp...4v preouts
well with the xenon amps u have to set the gains almost all the way...some that had the exact same amp got a pg line driver and he didnt have to put the gains all the way up nemore...he only had to put it like mid way...u think its a waste of money? i have the p80mp...4v preouts
let me explain how input sensitivity works. each source has different level of output, that's why an amp has a gain. the gain is only used to match the output from the source. it doesn't matter how far you have to turn up the gain. there should be no noise in a properly installed system. read the gain setting tutorial, but if you feel the need to piss away good money on a useless line driver go ahead. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
turnstylez18
turnstylez18
Toronto
turnstylez18
