line driver wiring questions???
pimpin
yerp
I have a DEI 500 amp, which is a 4 channel amplifier. I am going to be using the amp to power a set of components and a 8" subwoofer.
My questions are:
?how many RCA cables do I need?
I currently have 2 rca cables going to my 4 channel amp, now with the line driver how will I be able to up the volt in both of those channels??
can put in 4 rca´s? you put in 4
can put in 120 rca´s? you put in 120
My experience is the more you separate and widen your rca signal feed, the louder and clearer (with minimum distortion) your install plays
A typical install with a 4 channel amp uses 2 sets of RCA cables, front & rear. Fronts to the comps, rears to the sub (bridged output usually). No need for a line driver. If you have one, use it in the front channels, that's where the best impact would be for better s/n ratio.
pimpin
yerp
pimpin
Allentown, Pa
maylar
