line driver voltage higher than amp
As mentioned before, if there is a gain knob on the EQ, adjust it so that it does not exceed 5V at it's max level. If there is no gain knob, and you were to theoretically 8V to your amps inputs, you may clip the input resulting in some crappy sound. Odds are though some combination of volume/gain settings in the EQ or headunit should allow you to not send that maximum 8V from the EQ and you should be fine.
ughhibye
ughhibye
central florida
bball09124
