lightning audio storm vs Eclipse Titanium
Yeah the storm series is ligit, though i would not buy one...Go for the Eclipse Ti
WTF are you talking about? They are made by the same phuckin people...And the Storm has an advantage over the Ti.
The aluminum cones used on the Storm are actually much better than the Titanium. They are much lighter, but stiff.
I could go for the cheaper of the two.
For most applications, the Storm makes more sense. It's capable of every bit as much linear and peak travel, and has a nice surface area advantage over the Titanium (1" high profile vs 2" half roll surround), so you're looking at around 805cm^2 on the Storm 15 vs 650cm^2 on the Ti 15, so that means that in terms of both linear and peak output, the Storm should be capable of a good 1-1.5dB more output.
I'd get the Storm.
I'd get the Storm.
Can't really argue with that
I said that the Storm is a good woofer, though i would not buy one just because of my peronal prefrences, just because every time i think of lightning audio i see the bolt series that they selll in wal-mart. It would be like if Audiobahn came around and built a really good Spl/sql woofer, I doubt that many people on here would buy one, just because it is audiobahn.
FYI LA amps were used last season to set a WR in dB Drag //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
you need to look up on things before you make comments like this..
ltent
ltent
minnesota
ltent
