cutting out
i have a kicker 12l7 dual 2 ohm running off a crossfire 600 and the amp is turned way down but after a little while of playing the sub cuts out why?
If it gets worse, you probably have damaged tinsel leads or a damaged voicecoil. If it doesn't get worse you probably have an alternator that can't put out enough juice for the amp.
make sure the ground wire in still tightly intact while the subs are doing its thang it could be loosening up the ground wire and that would make the subs cut out and not make the amp go into protect mode
Was it recovered from under water:evil:
Sounds like a voltage/ground problem. Test the power wire during heavy play and read the voltage. Also re-check all of the connections. And make sure the wire guage and fuse are proper size.
liljp504
liljp504
new orleans la
tRiGgEr
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
