Lightning Audio LA-3000MD
Used Mechanically 10/10 Cosmetically 7/10 few scuffs
LA-3000MD SPECIFICATIONS
Number of Channels 1
Rated Power 600 Watts x 1 @ 4-Ohms
1,000 Watts x 1 @ 2-Ohms
1,400 Watts x 1 @ 1-Ohm
Max Power 1,500 Watts x 1 @ 4-Ohms
2,250 Watts x 1 @ 2-Ohms
3,000 Watts x 1 @ 1-Ohm
Bridgeable No
Crossover Controls 12dB/octave LP 35Hz to 250Hz
Subsonic: 15Hz to 55Hz
Tone Controls Frequency Range: 20Hz to 80Hz
Q-Control: Wide to Narrow
Bass Boost: 0dB to +18dB @ 45Hz
Phase: 0° to 180°
Signal Input Low-Level: 2 RCA (200mV to 6V)
Signal Output (2) RCA (slave in/out)
Power Input Connector Block connector w/ set screw
Power Wire Gauge 4 AWG
Speaker Output Connector Block connector w/ set screw
Speaker Wire Gauge 8 AWG
Heat Sink Type Extruded aluminum
Cooling Convection
Remote Control Bass Boost (included)
w/ integral Power LED & Protect LED
Visual Indicators Power
Protect
Circuit Topology Class Class D
THD at Rated Power
Frequency Response 20Hz to 250Hz
Signal-to-Noise Ratio >95 dB
Shipping Weight 15 Lbs. (6.8 Kg.)
Dimensions L15" x W9.4" x H2.3"
38.1cm x 23.876cm x 5.8cm
$180 paypal firm Shipped
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
175
CALIBASS2014
ZANESVILL OHIO
CALIBASS2014
    May 31, 2024
    May 24, 2024
