Lightning Audio LA-3000MD
Used Mechanically 10/10 Cosmetically 7/10 few scuffs
LA-3000MD SPECIFICATIONS
Number of Channels 1
Rated Power 600 Watts x 1 @ 4-Ohms
1,000 Watts x 1 @ 2-Ohms
1,400 Watts x 1 @ 1-Ohm
Max Power 1,500 Watts x 1 @ 4-Ohms
2,250 Watts x 1 @ 2-Ohms
3,000 Watts x 1 @ 1-Ohm
Bridgeable No
Crossover Controls 12dB/octave LP 35Hz to 250Hz
Subsonic: 15Hz to 55Hz
Tone Controls Frequency Range: 20Hz to 80Hz
Q-Control: Wide to Narrow
Bass Boost: 0dB to +18dB @ 45Hz
Phase: 0° to 180°
Signal Input Low-Level: 2 RCA (200mV to 6V)
Signal Output (2) RCA (slave in/out)
Power Input Connector Block connector w/ set screw
Power Wire Gauge 4 AWG
Speaker Output Connector Block connector w/ set screw
Speaker Wire Gauge 8 AWG
Heat Sink Type Extruded aluminum
Cooling Convection
Remote Control Bass Boost (included)
w/ integral Power LED & Protect LED
Visual Indicators Power
Protect
Circuit Topology Class Class D
THD at Rated Power
Frequency Response 20Hz to 250Hz
Signal-to-Noise Ratio >95 dB
Shipping Weight 15 Lbs. (6.8 Kg.)
Dimensions L15" x W9.4" x H2.3"
38.1cm x 23.876cm x 5.8cm
$180 paypal firm Shipped
CALIBASS2014
ZANESVILL OHIO
CALIBASS2014
