lifting, no more pain?
▼)Ñ╩fZΣµ&
3-4 weeks ago i started lifting weights, everyday , doing chest 1 day, arms, legs, back, shoulders, etc have a rotation
and i would destroy whatever i was working on, and the next morning it was tight, and sore pretty good..
now after 3-4 weeks i am going up in weight changing my exercises up, rotation between high reps, and low reps..
and now it doesnt burn at all when i wake up, so i dont really know if im actually ripping the muscle, or working it hard enough. but when im lifting i lift till it drops.. then lift some more.
but no soreness in the morning?? why? are the exercises doin anything?//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Your body tends to get used to the abuse and copes with it better. I have been lifting for 6 years and I barely feel sore after my workouts anymore unless I go at it super hard
The human body adapts..and this is just another way it adapts. After a while doing a repetitive motion, it becomes used to the routine and will stop burning. But you are still working out the muscles..
ok, i do change the lifts as much as i can, to give it a shock, but the weight is heavy but i feel no pain in the morning thats all..
im 19, was reading in my biology book, that with creatine and b12 will give you that extra energy able to keep you going longer, than regular lactic acid buildup
like it will allow more phosphate bindings or some crazy shit, which will allow you to go longer with more energy.. idk i read t but forgot
but when im lifting i feel i can just keep going alll dayyy if i take a 2 min break after each set, the muscles dont hurt but they cant lift lol....
BASICALLY nothing hurts at all, but my muscles like give out
lol...//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif i have no idea
I know what you mean, when I was heavy into lifting it would be very discouraging because you feel as if you're not accomplishing something. But what I would always tell myself was, if I'm still seeing gains, why stop?
It almost sounds like your over training. Are you going for size/strength or definition?
not over training, just want to bulk up, build muscle
simple, im an average white mesomorph 6' 175 and want to put more mass on all major muscle groups,
i know it doesnt happen in 1 months time but im ok with that, if i keep going everyday work a different muscle group, get enough sleep, i should see decent results in half a year, and longer the better i suppose..
definitaly sounds like over training and maybe hitting a plateau. take a couple day break then hit it hard again. you should see some good gains after the break
not plateau yet, i know when that comes.. the feeling of that
not there yet..
i think ill just keep doing this, and go lighter weight and do tons more reps.. for the last month its all been the heaviest weight i can do for 10 reps, and i see a definite difference in size, but ill go reps now and work the different muscle groups?
nah thats normal. i mean im sure you still feel it, but it aint where it is hard to reach for something, ect..
i get the samething and many ppl do. just normal after you're body adapts.
here is my schedule:: "i just pick like 3-4 of the exercises per body part per workout, (i dont do all that each session)"
Monday: back & chest
chest -
Flat bench press with bar
Flat bench press with dumbbells
Incline bench press with bar
Incline bench press with dumbbells
Dips
Back
Dumbbell one arm lat row
Cable lat pulldown to front
Seated back row on machine
Deadlifts
Bent over back rows
Lower back extension
Chin-ups (Pull-ups)
Shrugs for Traps (Dumbbells or barbell)
Tueday: cardio
Cardio - running, walking, jumping jacks, sit ups, ect..
Wednesday: legs & shoulders
Legs -
Squats Leg press
Leg curls
Leg extension
Stiff-leg deadlifts
Lunges
Calf-raises/presses
Shoulders
Seated military press with bar
Seated dumbbell shoulder presses
dumbbell side lateral raises
Bent-over dumbbell raises
Front dumbbell raises
Thursday : cardio
Friday: biceps & triceps
Biceps-
Alternate dumbbell curls
Straight bar curls
Cable curls
Hammer curls (forearms and biceps)
Ez curl bar curls
Triceps
Triceps extension (lying down) (Skullcrushers)
Close-grip bench press
Cable triceps pushdowns
Dumbbell kickbacks
Saturday: Cardio (sometimes a off day though)
Sunday: off
After awhile i got use to it and felt the same way, but believe me, if you're still training and doing it right, it IS working.
Keep up the good job. sounds like you got a good routine.
if you want soreness you need to push yourself harder and longer everyday you work out. I coach high school wrestling and the first 2 months of pre-season, training is hell for the kids b/c most of them don't work out on their own. I make sure they know that I know where their breaking point is. example, if i make them do sprints for 30 min on monday and they are dying, I know when i make them do sprints on wednesday we can go for atleast 40 min b/c they survived 30 min. if i have my 125lb wrestler benching 80lbs non stop for 1 min, i know i can make him do 90lbs for the same time a couple days later. you push harder and always think of how small the jump in either weight, rep, or time, i.e it's just 10 mins more, just 10 more pounds.
You're all over the road and setting yourself up for failure. If trying to add size stick to the basic compound movements, train 2-3 times per week, get more sleep, and increase calories.
A muscle does one of 3 things: gets stronger, gets weaker, or stays the same. Pick a rep range that you like and focus on getting stronger over the next 6 months. Put in the effort to add 20-50#'s to all your lifts and you'll get bigger. Poundage progression is the key...
not there yet..
i wouldnt go more reps. if anything i would do 4-5 reps in sets of 85% of max, 90% 95%,and one more at 95% or more. this has been proven to be the best way to increase size and strength.
ive been lifting seriously for 5 years now and i still get sore when i go with this plan
▼)Ñ╩fZΣµ&
▼)Ñ╩fZΣµ&
reno
MTX520
vegang
vegang
