less resistance = more heat?
whoever told you that is fuckin retarded.
//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
edit: you talkin about the amp getting hot? if so then yes, at a lower impedance load it has to work harder to put out more power. which causes heat. as for a wire or something though more resistance = more heat.
Wouldn't that be true though? Running an amp at 1 ohm vs 4 ohm would make it work harder thus causing more heat? Or do I have this backwards? lol
Isn't the lower number (1 ohm) less resistance than 4 ohm?
1. To pick a nit, resistance and impedance are related ideas, but aren't really the same //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
2. Use Ohm's Law to find the answer. At a half-ohm, you're talking about a lot more current than at 4 ohms for an equivalent power level. Most of the amp designs used in mobile audio will become horribly inefficient into such loads.
3. Like anything, there are exceptions //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Power, resistance, and impedance are three different things. If an amp uses and makes the same amount of power, then the heat is the same. 1, 2, or 4 ohms, it doesn't make a difference.
However most amps will put out more power at lower ohms. And more power equals more heat. Example you have a 1000 watt @1ohm amp, If you run it at 2ohms and 500 watts, it will be cooler. But not because of the load but because it is producing less power. Turning down the gain so you have 500 watts @1 ohm will also do the same thing.
If you can maintain proper voltage no matter the current draw, lower impedance is technically cooler as there is less resistance to overcome for the current. If you are talking about amplifier components, if you wire below the nominal impedance of the amp, the amp becomes the point of resistance and therefore heat builds up. The highest impedance part of an electrical system will always generate the most heat. The smallest conductor of an electrical system (and lowest voltage) have similar effects.
CHUCKmfnNORRIS
CHUCKmfnNORRIS
CT
wickedwitt
