Led DLP, LCD, or Plasma
I personally have always been a fan of LCD. I own a DLP (not LED) and the only thing I don't like about it is its not nearly as bright as an LCD, and when watching in 4:3/standard definiton the picture is bowed/pincusshion/flared/geometry is off, however you want to call it. Not only that but the silk screen is really noticeable to me. If I had the money for a plasma I'd really want to try out the Pioneer Elite/Kuro's but those things are expensive.
this again sounds like a problem with your DLP...
sounds like your screen has sagged or is not installed properly. also sounds like your screen could use a cleaning if you are noticing it...
And yes I clean my TV weekly...
http://forum.ecoustics.com/bbs/messages/2/136128.html
I have posted on avsforum as well. Many other users who own the same TV I have, have the same issues. You can look through the thread if you would like, it's not just my TV.
http://www.avsforum.com/avs-vb/showthread.php?t=665890
I have had Samsung come out and replaced my screen and tried to re-adjust my screen. It just has to be 1/4" and under for it to be "within" specs. But it's still well noticeable even when its 1/4" of a "pin cushion, hourglass effect is what they seem to call it too".
well, then it might not be "your" tv, but it is definitly "that tv" //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
thats not typical of a good dlp. again, my samsung has pristine picture quality that holds its shape all the time without a keystone error at all. and even when my screen is dirty, i still dont get any negative effects from it.
bought a Westinghouse 47" 1080p over the weekend and it looks awesome.
Reg is 1500 and i got it for $1000
if you dont have directv and need a hd tv best buy has a special "if you buy a tv over 1k and get directv you save 300 bucks"
I did that and cashed in some rewardzone points.
Anywhoo
If your not a hardcore videophile then its a good tv.
Its an LCD btw.
I really like it
I was going to get a plasma but I really didnt see to much of a differance in picture to be honest.
What model is your DLP? I've been told that ALL DLP's have some pin cushion, some have very little, some have a lot but they all have it. It is ONLY noticeable in 4:3 mode/standard definition. When watching something in full 16:9 it is hardly noticeable at all, most the time not noticeable unless you are really trying to spot it.
mine is a samsung DLP. ive never noticed any picture incongruities in it.
not to say it is the best, because i know its not by any means. but i have been VERY pleased with it since i go tit //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i also got the best buy warantee, so before that is up, ill be getting the bulb replaced fo free //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
You say it is definitely not "my TV" but it is "that TV". You and I have the same set, except yours is 6" bigger then mines. The thread I linked you to is for all the HL-S models. Mines a Samsung HL-S5087W. I have an extended warranty as well, not from Best Buy though. I'll stop posting here, I'm ruining this guys thread. What's your budget for your new TV?
bonesninja
bonesninja
Lima, Ohio
krisfnbz
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
