Lc2i help
So I'm running this lc2i off my stock h/u in my car which is a cts v and I'm using the speaker wires from the stock sub for the high in put and im not getting good sound it's in and out and when I turn the music up theres a cracking or popping sound out the subs my amp and subs are not the best but they worked good when I took them out my old car so I would think they should work now my question to you guy is where should I look first to fix this
Thanks for any help I can get a head of time
how did you make connections if you didn't solder? did you use crimp connectors and a proper crimp? i suspect your connections are loose. you should be able to pull on them and wiggle them and not have any movement in the connection.
I crimped all wires I used what I think is all the right stuff I did do some pulling when it was all done and nothing pulled out out of the connections but I will check to make sure it's all together
All Day Ray
Lancaster Pa.
CrossoverOre
