Lanzar opti2000d
rgplayer
Hey I just traded for an amp off here its a Lanzar opti2000d. When I go to set the gains with the dmm I start to turn it up and about half way it reads 20 somethin then goes down to 13.8 the input voltage. It doesn't go into protect mode or shut off. Did I get a bad amp?
I play a 50 hrz tone. Turn the amp all the way down. Start turning it up slowly. On dc voltage on the dmm. Once the gain gets about half way it reads around 25 volts then when I turn it up any more it goes straight to 13.8.
No it's not the exact same it jumps around on ac like it's supposed to, but once it gets passed like half way up it won't read over like 13 volts. I have seen it spike to like 30 something for a split second then right back down again.
My mean machine kinda did this....I have to set the gains at 20 volts to get RMS wattage and it would go up till it go to 18.87 volts and then stop rising...no matter how much more I turned it it never went past that.....
rgplayer
rgplayer
Oneida, TN
SubbinNCali
michigan born
    May 14, 2026
michigan born
    May 14, 2026
