Lanzar amp question
I'd say it's a solid 200w-300w x 2 @ 2ohm amp...
Pay NO attention to what the sticker on the amp says. How i figure out the "real world power" is take the simple fuse amperage multiplied by voltage then I assume probably 75% of that, just to be safe. that appears to have a pair of 30A fuses...?
60(amps) x 14(volts) X .75 = 630~ watts RMS
I run Power Acoustik amps right now. I was big into AQ, DD, DC, SD, etc... had to do a REALLY low budget setup this time so I went with a CPT1-5500D, Should get me a solid 2Kw RMS @ 1ohm. not horrible for $200 but the "5500 watt" sticker on it sure annoys me! LOL
Point being, overrated amps are OK to purchase as long as you know what you are getting. If someone bought the CPT1-5500D expecting 3500 rms, well they are stupid but they would also probably be upset. I have seen a few of the "5500's" checked and all were putting pout a clean 2200~ @ 1ohm. so, I spent the $200 knowing I was getting a clean 2Kw, therefore I am happy with it.
Well I was going to redo my system. Context: put this together my senior year of high school for less than $200
Wanted to replace 600w Sony Xplode, 2 500w 10" Duals and Sony Xplode speakers, not sure what they are, have the manual somewhere.
I was looking around and just saw they had that amp for cheap so I figured I could spend a few hundred to redo the system. Honestly, not sure what to look for. I got about 3-4 hundred bucks to spend though.
ASG1221
ASG1221
New York
ASG1221
