Lanzar 2000D running two 15s...?
Yes, its the Opti 2000D
700rms @4ohm
1600rms+ @1ohm (1600rms @ 1.3ohms)
I was hoping to run it at 4ohms so i can get away with using a 60-80amp fuse in my distribution block.
700rms @4ohm
well sure, it would work, but why would you want to choke off two monsters like that with 350w/pc when you have 800/pc at your disposal?
I know I would be unhappy with 350/per with those subs
ya 350w is not enough for L7's. 1 ohm would be so much better for those subs. Forget the whole small fuse crap, do it all right. Make sure you have 1/0 all around, big 3 done, and a n upgraded battery OR extra battery in the trunk. if your electrical is up to par, that optidrive will do you justice
Cheers all for the good advice! Appreciate it.
I think i have everything covered sufficiently on the electrical side; 0AWG power/ground with 200amp inline fuse, uprated battery.
I think im ready to blow my head off with BASS now //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
caraudiofanatic
caraudiofanatic
LA
caraudiofanatic
