Lambo Doors And Custom Wheels...
Only thing about the doors is you have to get a good kit and you may also have to get a weld on kit. Because I know the escalades do then it is non reversible. A good kit will run 1500 just for the hinges and being weld on the shop will charge you like 1200. You should be able to put 24's no problem you might even sneak in some 26's. But being that truck is a 4x4 and you prolly off road. I would go 22's with the toyo offroad tires. Nice 3 inch loud dual exuast liftyour door turn your music up and drive by as many girls as possible. Can ya dig it.
I got 24 inch Dub esinem rims with lexani 305/35/24 tires and no problems on the escalade. They do not rub at all. I have to agree with the post up there, I like the look of a 22 rim with some mud tires on it.....
Did you just say Lexani tires?!?
Wow. Lexani makes WHEELS... NOT tires.
Suicides are a ***** to wire up!! the whole wiring must be lengthened and re-routed near the new hinge. lambo bolt on kits are easier to install on front doors or so ive heard..
i would definately ******* my back doors tho.. alot less wiring and a much more classic luxury look
I've been thinking about putting ******* doors on my camaro for a while just because they are different but i really didn't consider how many wires there are until i looked. I'm considering putting just my drivers window and lock switch in the center console and getting rid of the rest. Where are good sites for ******* door kits?
magewulf
magewulf
Roosevelt, UT
bikinpunk
