kx800.2 &2 l7's
mtx11
Bump Till There Nuttin
i got it hooked up and i had the gian up to three mark before full bass boost all the way up. it hit pretty good. the subs are wires in series 4ohm and the amp is bridged. i tryied to set the gain on the gian setting tuter but i got it should read 60 volts. shit that dont slam //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
so what did i do wrong i was playing a 45hz track @ 60 volts
the subs are dual 4 ohm
4 ohm load, 800w, 4 x 800 = 3200, sqrt(3200) = 56.56, take it down a bit, 60 is clipping... And turn the bass boost all the way off, always, that is the easiest way to kill an amp/sub. If you arent happy, maybe try a different box (what is your current box), or might need to upgrade the amp....
a ported box would yield a good amount more output... especially on a pair of underpowered subs
exactly //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
port them suckers //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
mtx11
mtx11
lehighton , pa
Polecat
