400-500w rms -- http://www.sonicelectronix.com/item_9343_MB+Quart+RAB+1450.htmlhow many watts?do i jus wire both subs to the one speaker port
Sorry, I thought they were dual 4 ohm coilsok let me get this straight i take the 2 negative wires and the 2 posative wires and run the both to the 1 channel mono amp at 1 ohmthe subs r single voice coil idk if that makes a diffrence
no the subs have 1 terminal a negative and a posative on eachthe amp will do 1000 rms at 1 ohm and around 600 at 2 ohms so you will be fine with it. i thought u had dual coil subs you only have 2 terminals on each sub?
