Knukonceptz wire on Power Acoustik A2400DB Amplfier...HELP PLEASE
HardCoreSound
Wide Reciever Brap
Hey guys,
I was thinking of getting a knukonceptz wire kit for a Power Acoustik A2400DB amp.
I was going to get the, KLM 1/0 Amplifier Installation Kit, would that be a good choice. Also it says i need a fuse size what would that b efor the PA A2400DB?
Im also going to get a speaker amp so is some 4 gauge wire fine for that?
Also would i need a Distro block? Which one should I get?
Thanks.http://www.knukonceptz.com/productMaster.cfm?Category=Distribution%20/%20Fuse%20Blocks
THANKS very much god bless!
For the fuse up front -- I'd allow 120 for the PA plus whatever else for the speaker amp.
I'd use this for the d-block -
http://www.knukonceptz.com/productDetail.cfm?prodID=KNF-23
From there you'd run the 4 ga to your speaker amp through the appropriate sized fuse.
For the PA power wire I would probably use the other 1/0 connection on the input side since it doesn't need to be fused, but if you want to fuse it you can (~120). You could run 1/0 or 4 from there to the amp - a little less v-drop with 1/0. With 1/0 you might need a 1/0 to 4 ga reducer to connect it to the amp, the cheap way would be to just trim strands off until it fits - it would be effective though.
HardCoreSound
Wide Reciever Brap
HardCoreSound
Terrel Owens look alike
n2audio
