KnuKonceptz: Amp Installation Kits
I ordered my subwoofer (Sundown SA-12) and amplifier (Hifonics BRX1100.1D) a couple days ago and the only things missing for my setup are wires. I want to buy from KnuKonceptz because it is the least expensive in Canada (so do not suggest me other brands please).
1. I just wanna know if there are any difference that should worth the money between these kits:
http://www.knukonceptz.com/productDetail.cfm?prodID=KOL-AK4
4 Gauge Amplifier Installation Kit
Also, I plan to do Big 3 and I have all stock electrical now. Here are some questions:
2. Do I really need to change my battery terminals or I can fix ring terminals on my stock ones?
3. Some say it is better to place the fuse closer to the alternator, while some say closer to the battery. Any suggestions?
Thanks.
Buy the 1/0 gauge kit. So you won't need to upgrade in the future..
Use 1/0 gauge solder ends and buy a adapter bolt for the battery.(side mount) you will need to upgrade battery terminals if your going to do a big 3 upgrade.
I upgraded All my wires under the hood with knu 1/0 gauge and soldered ends plus a 220a alternator
I placeed 2 250a ANL Fuses about 12" from the battery on the 2 1/0 gauge runs back to the trunk hooked to 2 C&D batteries and 2 BC3500s
Well ur anwser to number 3 id say alt ur pumping it.out the alt to.the battery thats were i.have mine and ive seen people.not even use fuses so.i guess to.each is different just my 2cents
Golitan11
Golitan11
Canada
urmomsmin3
Mike Mccabe
