KNUconceptz/ What do you have?
What kind of noise? Chances are the noise has nothing to do with your RCAs.
static at low volumes/engine noise? who knows.
I still need to purchase a 4 channel RCA cable and am trying not to waste money on cheap cables. Ya know
static at low volumes/engine noise? who knows.I still need to purchase a 4 channel RCA cable and am trying not to waste money on cheap cables. Ya know
Noise induced into your signal cable will have the same presence, in terms of output in relation to the signal (music), at any volume level. This is because the noise is introduced into the signal chain before the amplifier, so the amp amplifies it just like its suppose to be part of the original signal.
Engine whine is primarily the symptom of a grounding problem, not induced signal noise, which is usually in the form of a magnetic field caused by a significant amount of electrical current passing nearby. Engine RPM's generally dont affect the current strength of a major wiring system in your vehicle, other than the ignition wires. And if your RCA cable is running anywhere near your spark plug wires, you've got bigger problems.
It sounds like you are trying to solve a problem you may or may not have.
I have Karma SS 19.5ft and they very nice...only complaint(and you hardly ever hear this one) Is that once the RCA's go on they are tighter than virgin ****** ! Very hard to pull off!
in their description "Each end uses rubber o-rings to provide a sure grip for installation of the Karma SS Kable. " lol
I have several pairs of Krystals I've used since 2005 - great build quality, although the size of the connectors does make repairs difficult if you have to resolder them, there's a lot of metal to have to heat up //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Not a bad problem to have...
Kastlez_
Kastlez_
Bay Area, CA
JimJ
BP1Fanatic
BP1Fanatic
