Sold Kinetik HC600 Battery
n2caraudio
1. Product:
Kinetik HC600
2. Specs:
Weight: 14lbs
Ah: 20
Dimensions: 7"x3"x6.5"
Suggested Retail: $199.99
3. Description/Condition:
Brand New, havent even taken it out of the box
4. Price: :
$99 shipped
5. Pictures:
Question though, Do I need to run 2 lengths of 0 gauge to the trunk if I run a second battery and then run pos from trunk batt to amp and neg from trunk batt to amp?.....ive never ran a second battery before and cant find a diagram anywhere. im used to a single + run and chassis grounding the amp.
You can do it two ways. One is to run both positive and negative from the front battery to the rear battery, then run them from the rear battery to the amp. Or you can run just the positive from the front to the back. Then from the positive of rear to the battery. Then ground the amp to the frame and ground the battery to the frame.
Awesome you covered everything lol.
This will be fine without upgrading my alt and stuff right?. The only other thing I was planning on was the big3 if I can stop myself from being so **** lazy.
n2caraudio
n2caraudio
California
n2caraudio
