Kinetik Batteries?
1) yes they do fine2)use the size that fits in your factory location, you can tell that by matching your current battery size to the sizes of kinetik batts
3)no
I know that you answered no to my question about amps drawing off the starting battery. I also know that the amps dont draw off of the starting battery when the car is off, but I was asking if they draw off of the starting battery when the car is on? Sorry for the vagueness of my question
Dang I didn't know that. So I guess the starting battery isnt that important when an isolator is used. So if I put a hc2000 upfront I wouldnt notice a difference in voltage drop on long bass notes than with the redtop I have now?
If your gonna use an isolator just put a cheap battery or keep your optima in the front for starting and car accessory purposes dont waist your cash for a hc2000 that is not going to support any of the audio.
I've talked to Kinetik plenty of times and they said to go with 2 of the same models so they'll last longer, but of course everyone runs different batteries up front and back and they don't have any problems though.
Just my 2 cents.
(Mr. Penn is da bomb)
I dont know. Bought batteries at different times for different setups. Started with just the redtop, needed more power bought the stinger, needed a little more power my cousin had a hc800 for cheap so I added that. Probably will keep the redtop upfront and get rid of the stinger and the hc800 and put hc2400 in the trunk. I just want one battery in the trunk.
I've talked to Kinetik plenty of times and they said to go with 2 of the same models so they'll last longer, but of course everyone runs different batteries up front and back and they don't have any problems though.Just my 2 cents.
I though isolators eliminate this problem.//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Im just saying your mix and matching to much; agm and gel and weak links with powerful ones. If you can have all the same battery its always better but to mix different technologies is almost crossing the line if your wanting the max out of everything you paid for. Especially since the charging rates is much different between gel and agm.
isolators do eliminate the problem of varying charging rates between different brands. but if you start your car daily you probably won't shorten the battery's lifespan by that much having different brands anyhow. why? the alt will charge them both once the car is turned on
And no. An isolator is for mainly people who like to sit there with there car off and play there system till the batteries die.//content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif I know dumb right. But since they have an isolator they can still start there car cus the front batt is not connected to the audio system in no way shape of form.
You understand!!!
You understand!!!
Chill man I gotcha.
[/b]
Chill man I gotcha.
Im not loosing patience im just seeing if you understand what im saying but you can't here tone of voice over the computer can you. //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
My bad!!!//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Crownvicon28s
God 1st
Crownvicon28s
Spartanburg, SC
alvitae
slater
    Oct 4, 2025
1aespinoza
    Oct 4, 2025
