SHOemup233
NooB!
That isn't how the charging system works, in the aspect of charging at least. You can go on believing that though.That is why it is important not to mix batteries. Yes it will work for a while, but over time you will see a premature failure of the smaller battery.
As for the batteries themselves, they won't have premature failure from charging at 14.4 volts //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif. Put simply, if no music is playing and that specific car sits at 14.4 volts then the batteries will be fine. If music is playing, the car will most likely not be sitting at 14.4 volts as the amps will be drawing power, so they won't be sitting at 14.4...which according to you is "overcharging."
