Kinda Pi**ed
snick
well i posted on here a lil bit ago about a ported box for a l5 10''.
i made it 2 cubes at 32hz
the thing is is that it hits the lows pretty good but my sealed box sounded kinda louder.
i have subsonic on
one of my lil wires on the sub that go to the middle of the cone is broken.
i dunno if that is why.
i have bass boost all the way,
gain about in between 1/2 and 3/4 up,
and x-over at about the middle
the amp i have is a kx400.1
i thought i needed bass boost to get that extra thump.
so it will hit harder without bass boost.
should i turn bass boost all the way down on my amp and head unit
i will try and get a new one wed. if i got time, and let u guys know how it sound's with a new sub
but did i make the right desicion goin to 32hz
if it's in a ported enclosure you don't even need to use bass boost since the bass in a ported enclosure is less distorted then a sub in a sealed box.
Dont meant to Hi-jack the thread, but
Im confused, if ported enclosures give you less distortion from the bass, then why is it that sealed = SQ?
Distortion
At moderate power levels all of these enclosure types exhibit pretty
decent manners. The ported box and the bandpass designs produce less
distortion than the sealed box, but the difference is marginal.
At higher power levels things change considerably. The dual-reflex
bandpass, due to the fact that its ports control cone motion over a
wider range of frequencies, produces the least distortion and exhibits
the best power-handling characteristics. The ported enclosure and the
single-reflex bandpass also do a very good job producing high-levels of
undistorted bass output, again due to reduced cone motion in this
frequency range. Bringing up the rear in this category is the sealed
enclosure, which produces higher levels of distortion at high power
levels. There is a common misconception that ported designs produce
more distortion than sealed boxes. As you can see this is not entirely
accurate; it depends on the frequency and the power level.
Transient Response
Transient response refers to the ability of the subwoofer system to
reproduce quick changes (transients) in the program material
accurately. This is often interpreted as "tightness" or "looseness"
which is maybe a dangerous terminology since many people are more
influenced by tonal characteristics when asked to qualify the
"tightness" of the bass. Transient response is actually a function of
accuracy in relation to time rather than frequency. In music, sounds
like drum strikes and quick bass guitar pulses are good tests of a
subwoofer system's transient performance. A system with good transient
response will reproduce these sounds with clear, "tight" definition. A
system with poor transient response tends to blur these sounds over
time, due to the speaker's inability to stop and start quickly enough
to react to the signal accurately.
It is generally accepted that an optimized sealed enclosure exhibits
the best transient response characteristics. The control provided by
the air-spring in a good sealed system contribute to generally
outstanding transient behavior (at very high power levels, the
increased distortion can overshadow this advantage, however.)
A ported enclosure can also achieve good transient behavior but never
as good as an optimized sealed enclosure. It is possible, however, for
a well-designed ported enclosure to have better transient response
characteristics than sealed enclosures with higher Qtc's (above 1.0.)
The specific alignment of the sealed and ported enclosures plays a huge
role in determining the transient characteristics of each individual
subwoofer system.
Single-Reflex bandpass designs can also have good transient
characteristics if their bandwidth is fairly narrow, but again, not as
good as an optimized sealed enclosure. As the bandwidth becomes wider,
their transient response can degrade considerably.
Dual-Reflex designs generally exhibit inferior transient response
characteristics when compared to the other designs. As with
single-reflex designs, narrower bandwidths produce better transient
performance than wider ones.
distortion or transient response?
*sigh* Not this discussion again.
Sealed boxes give you a flatter, more natural response curve. Vented designs give unnatural spikes in output across the frequency spectrum (not a flat response). This is the main reason to chose sealed over vented for SQ applications (phasing is another reason).
JL Audio and I disagree on their wording. I know where they are coming from though: vented systems control cone motion more, so less cone motion = less distortion. In very simplistic terms, thats true. But for a given excursion level, vented enclosures (single reflex and dual reflex) do not output less distortion. Also, distoriton is a bit harder to hear in vented designs (especially bandpass). JL's wording is very misleading. For example, a bandpass enclosure is very good at masking distortion noises the speaker may be making. On the surface that seems like a good thing (as JL's wording implies), but it also leads to problems. You can be doing great harm to your speaker(s) and not even realize it with a bandpass.... the sub's in there banging away and all you hear is that boom-boom-boom one note wonder. The sub's in there stressing, and the box is making a single note sound that's overpowering the rest of the system, but hey JL Audio says its less distortion than a sealed system would be... must be true SQ there right?
"Distortion" can be described many different way. There's signal distortion, speaker distortion, and there's sound wave distortion. Disrupting any of those three ultimately 'distorts' the final sound. *shrug*
snick
snick
michigan
snick
michigan born
    May 14, 2026
michigan born
    May 14, 2026
