Killer Sub if it works......
  • 2
Free_Style
Chicago
I have been trying to figure this out. I have a 12" dual voice MB Quart PWD 304 and a Phoenix Gold TI 400.2 amp. I knew nothing about dual voice coil until reading crutchfield. Now I think I have it hooked up wrong. I put one negitive wire and one Positive wire on both sides. Should I bring the 2 wires to one side and then loop 2 more wires from that side to the other. (hope im making sence).
If you bridged the amp and hooked the voice coils up in paralell it should be fine. If you hooked it up in stereo It would sound bad and damage the speaker.
What is hooked up in stereo? I hooked both wires to one side and left the other side empty. And I did bridge the amp. I am asking if I should bring anthor set of wires to the other side of the basket. I am thinking that each side of the basket is for each voice coil. The speaer does not pound like I thought it would this is why I think I need a diff wire config.
The answar to your first question is yes you should connect to one side then loop around to the other. So that the coils are wired together in paralell.
thanks DB, that definitely helps swallowing a $300 price tag 😂 these would essentially be running midbass for me too
12
253
What is your budget? With being exposed to Rain.. I would recommend looking at a marine grade SAS Bazooka for the sub stage
407
Don't forget Hoffman's Iron Law. You can have 2 of the 3: low end, efficiency/sensitivity or small enclosure size...
4
515
In that airspace you could go ported with th Si SQL 12@$369, hands down the best option in a 1.41 ported box. With 1000 watts RMS and 92 db...
16
829
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
531
Free_Style
Free_Style
Chicago
indosia
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
