Kicker ZX460
  • 4
Rightbrained
SOLD , thanks !
Kicker ZX460 4 channel old school power.
The amp is in great condition and includes the SWX module.
# 2-, 3-, 4-channel output
# Tri-way capable (Tri-Way crossover required)
# 30 watts RMS x 4 at 4 ohms
# 60 watts RMS x 4 at 2 ohms
# 90 watts RMS x 4 at 1 ohm
# 120 watts RMS x 2 at 4 ohms in bridged mode
# 180 watts RMS x 2 at 2 ohms in bridged mode
# stable to 1 ohm in stereo, 2 ohms in mono mode
# frequency response 10-28,000 Hz
# MOSFET power supply
# requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
# rear channel switchable high-pass crossover (100 Hz at 24 dB per octave)
# discrete output transistors
# silent turn-on/off circuitry
# removable endcaps and logo plate
# 14-9/16"W x 3-1/16"H x 10"D
$85.00 shipped (lower 48)
so it would be full range correct..?? i have a kx kicker now, doesnt sound to bad just using the decks eq... LOL
had a soundstream 5.0 on my highs but it was W A Y to much... did sound AWSOME tho
Not car equipment. What do you have for home audio?
A few things, mostly o/s equipment. Maybe trade me for my Kenwood KA-V1000R integrated amp? I'll include the highly regarded matching tuner if you pay my shipping...
It's an 80s amp, but not black plastic crap like most Kenwood products from that time. It's actually black metal, and I believe it puts out an underrated 80watts for each of the front channels and like 40 per rear channel...It's a quality amp, don't let the black face tell you otherwise...It's in 9.5/10 condition internally and externally, no scratchy attenuation or anything like that.
686
Rightbrained
Rightbrained
LA.............Lower Alabama
Rightbrained
    May 20, 2024
    May 20, 2024
