Kicker ZX460
  • 4
Rightbrained
SOLD , thanks !
Kicker ZX460 4 channel old school power.
The amp is in great condition and includes the SWX module.
# 2-, 3-, 4-channel output
# Tri-way capable (Tri-Way crossover required)
# 30 watts RMS x 4 at 4 ohms
# 60 watts RMS x 4 at 2 ohms
# 90 watts RMS x 4 at 1 ohm
# 120 watts RMS x 2 at 4 ohms in bridged mode
# 180 watts RMS x 2 at 2 ohms in bridged mode
# stable to 1 ohm in stereo, 2 ohms in mono mode
# frequency response 10-28,000 Hz
# MOSFET power supply
# requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
# rear channel switchable high-pass crossover (100 Hz at 24 dB per octave)
# discrete output transistors
# silent turn-on/off circuitry
# removable endcaps and logo plate
# 14-9/16"W x 3-1/16"H x 10"D
$85.00 shipped (lower 48)
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
417
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
921
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
Rightbrained
Rightbrained
LA.............Lower Alabama
Rightbrained
Latest topics
