Kicker ZX350.4
your gains are under half? did you set them with a DMM?
also check your grounds. ive had a heating issue with one of my older amps and it turned out to be a ground issue.
your gains are under half? did you set them with a DMM?also check your grounds. ive had a heating issue with one of my older amps and it turned out to be a ground issue.
yup, set to the proper output. Kris can verify that...
ground is fine.... and its an '06 amp...
Ku-sama
Banned
Ku-sama
Dover, PA
Ku-sama
