kicker zx1500 or dc audio 2k amp?
if its twice the price i would get the kicker. You won't hear the difference of 500 watts most likely. The zx1500.1 is a strong amp especially if ran at 1 ohm. I would suggest running it at 2 ohms though but its still good for 1700-1800 watts. The only thing is they are designed to play at different ohm loads. So if you need a 1 ohm amp get the dc, if you need a 2 ohm amp get the kicker. I do believe that at 1 ohm the kicker is stronger than the dc, have seen tests on the kicker at 1 ohm(around 2300 watts) but not sure how underrated the dc might be
yeah i plan on buying one dc audio xl 15" rated for 1500 watts rms. I wanted to know if i could save myself a few bucks by getting the kicker amp without effecting the most performance for the sub
I'm running my XL on 1500 and it seems to be a little more power hungry than that so I'd say either go with the DC 2k or an AQ2200d. the AQ is about 35 buck cheaper than the DC but I was told they use almost the same board.
Those BRZs are pretty legit. I dont know about THD wise (I dont care much on mono amps honestly), but I think the BRZs definately do their power and then some
i have a kicker zx1500.1 and i love it i needed power at 2 ohm so i would say depends what ohm load u are going to run first before u buy a amp
what amp would ya'll recommend me a 2400watts hifonics? or a zx1500. kicker amp? i had a 1600watts brutus and well it sounded pretty good but just dimmed out my lights pretty bad even when i had a red top and two capacitors.
dont thread jack, if you have a lagit question make your own thread for it.
op. what VC config of the xl are your getting, if its the dual 1/.7 go with the kicker and have power at 2 ohms. if its dual 2/1.4 then get the dc and run it at or just under 1 ohm.
cash94
cash94
Boston, MA
Phoenix Risen
