Kicker Zx1500.1
DeGr33z
Kicker is God
I just got this amp from the ups guy yesterday. I use to run a hifonics brutus 1600watt mono @ 2 ohms >1100 watts. I got a small car with a 15 L7 in the trunk. I just installed this amp and i got the gain at about half, bass boost a little bit before the half mark, and x-over at about the first mark. My kicker is d4, wired to 2 ohms for 1500 watts from amp, but i guess my question is, like when i first got the brutus i smell a little bit of burning, but no smoke. My kicker is kind of new. It never really got a work out. Do you think its just the glue burning from the sub and the corners are breaking in? This kicker amp pushes out power.
I didnt think it was to much power,but it might be. What im not undrstanding is, i see guys running rockford power 2000watt mono's on 1 kicker and the sub still looks hungry. Not saying rockford is better than kicker,but im pretty sure that a 2000watt mono power amp can out perform a kicker 1500 watt mono. Guess what im trying to say is,i thought it would be a perfect match for the s15L7.
Well they do make RMS ratings for a reason. However powerhandling is greatly affected by the box involved.
Not sure of the specifics, as I am still pretty new to the diy stuff.
But 500 watts over the rms, cuz the zx1500.1 is underrated, seems to be a bit of overkill. If it really was able to take that in most applications, they would have raised their ratings.
U can keep the 1500 hooked up to it, just keep the gain lower.
turn off the bass boost. I have that same amp and my bass boost is off, my gain is less than 1/4, and i crossed it at around 70hz, You will blow the sub if you keep the bass boost on. You're clipping the amp right now and the sub can't handle it.
DeGr33z
Kicker is God
DeGr33z
BaTon RouGe,La
youngmillion
vegang
vegang
