kicker zx 2500 vs the rockford 2000 bd
Soooo according to Mr Tracy 30 % normally huh ? What's 30 % of 2500w again ? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
30% seems a bit high.
I've seen them vary from barely over 2500 watts to over 2800. It's all luck of the draw really. Mine is rated at 2688w.
Either way, the zx2500 is a tank of an amp. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
1ohm daily stable?burp lower than 1ohm?
My teammates run them at 1 ohm daily. They CAN go into protect running at 1 ohm if you are really hard on them, but for the most part they are fine.
We have gotten one to burp running at .5, but it was VERY picky and I wouldn't recommend that anyone do it.
750 //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif I havent seen that though most 2500 are around 2800 or so. Wich would be my frirst statement
Same way with the rockfords . I have seen some as high as 900w and some as low as 300w //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
As is the T2k , both are very solid amps //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Agreed.
I guess it comes down to which one he would rather have and his budget. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Same way with the rockfords . I have seen some as high as 900w and some as low as 300w //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif QUOTE]
Ive only seen a few. They were above 700 on the ones Ive seen. I agree both are good amps. Go for the one you can get cheapest.
if you need 2ohm go kicker, if u need 1ohm, go rockford, if you have manuf. warranty, you dont want to blow anything by dropping it below manuf. loads. juss my 2 cents. both amps will do the job, just fit the one better to what your needs are
youngcoke
Banned
youngcoke
chicago
camry_tuner
