SOLD Kicker ZR360
xxxbasshead
Kicker Zr360
does not have the kicker badge or a crossover module included
Details:
* stereo or bridged mono output
* Tri-way capable (Tri-Way crossover required)
* frequency response 10-28,000 Hz
* 90 watts x 2 at 4 ohms
* 360 watts x 1 in bridged mode at 4 ohms (underrated and will run at 2 ohms bridged, not sure about 1 ohm tho)
* 180 watts x 2 at 2 ohms
* MOSFET power supply
* module docking port with 2-way active crossover (80 Hz low-pass, 100 Hz high-pass, 12 dB/octave)
* discrete output transistors
* silent turn-on/off circuitry
* removable endcaps and logo plate
* 18-3/8"W x 3"H x 10-1/16"D
10/10 mech and id say 7/10 cosmetic
175+ship OBO
Will add cash for a good trade.
actual shipping cost thru carrier of buyers choice
Mine will take 1 ohm for short periods. They overheat quickly at 1 ohm, and eventually the smoke will come out the box... Should be fine for comps/temp stuff but not for daily. I run mine at 4 ohm on a TC-1000 and it is great, these are clean sounding and are underrated for power. They're great with mids/highs too.
they are 1 ohm stereo capable and rated for it
they are also 2 ohm bridge rated as well....
http://www.kicker.com/sites/default/files/ZRAmpsMan.pdf
they put out the most power 1 ohm stereo / 2 ohm bridged FYI...
brother is running 4 of his 8 ZR amps at 1 ohm stereo... powering D2 subs with them...
most I have ever ran them at was 1.33 bridged iirc but I do not recommend it since they are vintage amps..
we used to use em to run the 6" F series ( free-air ) kicker midbass with the reso series comps.
bump, bought a SWX crossover module should be arriving by friday //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif so that will also be included now.
789
xxxbasshead
xxxbasshead
lake forst , ca
xxxbasshead
    May 31, 2024
    May 24, 2024
