kicker soloX
snow96
PIMP
125
Texas
has anyone heard about this new speaker from kicker..it is an 18" like the L7 but it is rated at 5,000wrms and 10,000wmax.......what amp could possibly push this monster....http://kicker.com/ShowPage.cfm?filename=SoloX.html&menu=SUBWOOFERS
there are amps, i think from audiobahn that are 5,000 rms beasts, but kicker wires like 4 of their 1250wrms to it, and its a special woofer cause its rated at 1 ohm! so i think you could buy like a certain amp thats rated 2,000 or even 1,500 @ 4 ohm, and then have it so it safely goes down to 1 ohm, and wire it up!
two orion 2500d's will punish the solo x.. //content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif
This tipic was all over the place way back.. The Audiobahn Amp bites from what I heard.. and well.. You could get anything to push it.. Susposedly it does well even with only 2000 sent to it.. //content.invisioncic.com/y282845/emoticons/boring.gif.42c69fa49b1e73e6332d62b462a2a4b3.gif
In that case one Orion 2500D should be more than enough. Another good amp is the Planet audio 2250D
I'm incorporating 2 of 'em hopefully in my setup.. We'll See.. It's All In The Install.. & Well.. In this case.. Electrical.. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
ill believe it when you post up some pics.
609
snow96
PIMP
snow96
Texas
denim
    May 16, 2024
    May 16, 2024
