Need some quality 6.5 speakers..
Hybrid-X
I'm going to upgrade my entire system, but am not really up to date. I've pretty much decided on my other components, but this is pretty much the last step. I want to build a real quality system so I want the best this time around. I've spent a good chunk of change on marginal components and I'm ready to upgrade. That said, what are really good or the best 6.5" speakers?
I basically want something that sounds clean at high volumes without distortion and something that can handle alot of heat. I want to do it right this time so money's not an option. Any help would be greatly appreciated. Thanks in advance! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Thanks for the reply. That looks like a pretty sweet setup. Another question I had is what amp to use with these speakers. Again, I want something that has more than enough power so I can get full potential. Thanks.
If your on the price is no option mode I would say Power acoustic 6.5 are the best //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Na...I'm playing...really Focal Utopia line. CDT are really nice too. I think that the Focal have a bit better sound to them though. Amps for that is a good question. Not totally sure on that...but I would guess any high end amp would do, Mcintosh perhaps? Great clean sound there.
You can also check out other high end speakers from bostons top of the line the Z6.
http://www.bostonacoustics.com/ca_product.asp?ProductID=216&CategoryID=14
I heard a lot of good reviews with the Dynaudio speakers.
http://nexxon.com/dynaudio/dynaudio.htm
This is what i will try next when i get a new car.
Ofcourse Focal speakers, which what i have in my subaru.
http://www.focal-america.com/catalog/utopia/main.htm
Regarding good amps, it is really hard to notice the difference in sq of between different brand of amps.
But i assume that more expensive amps will sound cleaner.
My friend had zapco amps in his system and they sound really nice compared to my US Acoustics. But the price difference is double or tripled.
Some nice amps i know of are zapco
http://www.zapco.com/nosound/index3.html
xtant
http://www.xtant.com/html/
arc audio
http://www.arcaudio.com/arc/navigation/products.htm
Brax and Helix amps
http://www.theautophile.com/products/BraxNavFrame.html
Brax makes one of the expensive speakers in the world.
The Graphic Pro 6 1/2" 2-way "Reference" Component Speaker System $2,500.00, i dont know if they are worth the price.
You can also check out other high end speakers from bostons top of the line the Z6.http://www.bostonacoustics.com/ca_product.asp?ProductID=216&CategoryID=14
xtant
arc audio
Brax and Helix amps
Awesome...thanks for the help. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
If you're in the Bay Area, near Mission St. there is a whole lotta car stereo stores you could check out. Sometimes you gotta listen for yourself. Not to say any of the mentioned speakers are bad, lol.
I love my Diamond Audio 6.5 comps. But I rarely see anyone on this board talking about them. On a different note, I saw one of their HEX subwoofers in action and I was stunned. Never seen a JL W7 but this thing was incredible.
Focal 165 K2P
http://www.focal-america.com/catalog/K2%20Power/165k2p.html
2 way separate system.
165mm (6-1/2") woofer,
40mm (1-9/16") v.coil,
100mm (4") magnet.
TN 52 tioxid 5 tweeter.
Separate crossover
18 dB/oct. (3.8kHz).
Adjustable tweeter and midrange level.
Max. power handling: 200W.
Nominal, power handling: 100W.
Sensitivity (2.8 V/1m): 92.5dB.
Frequency response:
70Hz-22kHz.
Grills included.
$499.00 at http://www.onlinecarstereo.com
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=13571
id go with focal utopias.....much cheaper than the eurosports. ur not gona get much better sound than these 2 speakers. I dont see how u guys are saying some amps sound clean u cant tell SQ difference amps. Any decent amplifier with the right amount of wattage will be fine. No need to waste money on Mcintosh or Zapco.
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
187
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
218
Thanks man! Quitting drinking and battling DRESS syndrome has given me a new outlook on life.
8
549
11
497
If you can find these in your area. Id recommend these for drop ins. They play from 40Htz on up. Sound very nice on amplified power for premium...
Hybrid-X
Hybrid-X
Bay Area, CA
Hybrid-X
slater
    May 2, 2024
slater
    May 2, 2024
Latest topics
