Kicker S12L7 Ring/Square
  • 5
Hey guys.
I'm having a hard time finding a Kicker S12L7 ring/square. Its the part that goes on after you screw all the screws in to hide them.
It's the part that says Kicker in each corner of the attatched pic.
Any ideas where I can get one? Mine is missing and its doesnt look as good without it compared to the brand new enclosure it's in. Also, I only need one...but if I can only get them in twos, that's fine.
I was looking at the grilles, but no way I went to spend 30$+ for a pair of grilles when I just need the ring.
Thanks in advance.
EDIT: Can someone tell me the proper name of that part so I may try to find a one?
20051
370
901
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
HighlanderAudio
HighlanderAudio
Tulare County, CA
Bobbytwonames
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
