kicker pdk1 1/0g amp kits
denalilvr
just laugh
the system consist of 4 subs,3amps,2 sets of components,2 batteries under hood and 2 batteries in the back
the kicker pkd1 amp kits comes with
# 20 Ft. 0/1 AWG Power Wire
# 3 Ft. 0/1 AWG Ground Wire
# 20 Ft. 16 AWG Remote Lead
# Fuse Holder
# 300A ANL Fuse
# 2 Distribution Blocks
# 5 Ft. 4 AWG Power Wire
# 5 Ft. 4 AWG Ground Wire
reason i ask is im having a shop near by who has done work for me in the past and i want to buy the kits online but im not 100% sure how many kits i will need? by the way its going in a truck a gmc yukon denali
i think they are out of stock on the kit i need, but that does sound better..problem is im not what youd called a pro with wiring, so if you guys can give me an idea of how many feet of wire i need i can buy them and just pick up a couple of other stuff..
it all depends on the distances. Take some scrap wire (if you have some) and see how long the distance is between the front batteries and the rear batteries, then multiply by how many lengths you need in between batteries
measure distance from the battery to where your amps will be mounted, plus a foot or two for safety, and buy that much
then just figure out how many terminals you will need and whatnot
it never hurts to buy in excess though, if you have the $$$. you can always sell the extra on here.
i basically went and looked for everything the kicker kit gives you and it ends up costing $40 more..but thats not a problem if its better which i heard great things about them..so heres where im at
Kolossus Kable 4 Gauge Blue Power Wire
KND-23 KonFUSED Ground Distribution System
ANL300 Silver Plated 300 Amp ANL Fuse
KLM4BL KLM Kable 4 Gauge Metallic Blue Power/Ground Cable
KLM0BL KLM Kable 1/0 Metallic Blue Power / Ground Cable
KOL1/0BL Kolossus Kable 1/0 Blue Power Wire
fuse holder
total $144
so far now besides the 1/0 g wire which i think i will end up needing about 100 feet minimum can you guys give me some opinions on how much of what i'll need?
now i havnt used the fleks cable form knu, but the kolossus is no where near as good as the kicker, my opinion is get the kicker kit and then grab extra wire form KNU, i believe the kicker kit has that exact specs for like 80$, kicker is a far superior wire compared to the Kolossus
*i have both in my truck and hate using the KNU wire if i can help it compared to the kicker*
i just dont see spending almost double for no extra benefit, i use the cheap 1/0 knu wire for the big 3 and it works perfect, would hate to have to run it in my truck though
you gonna need atleast 3 sets of RCA's(16or so depending on the vehicle) and probably some splitters and short RCA's(3ft or so)
get like 10 or so crimp on terminals for which ever size wire you use, probably 1/0 and some 4ga
what you need to do is just draw everything out on a piece of paper and just write down what you gonna need to get signal, power, ground, and speaker wires for each amp, then go get a tape measure and measure everything out giving some extra incase of trouble
you know how rockford fosgates site has that wiring wizard where you enter how many subs,what voice coil and it tells you which ways you wire in ohms..is there something out there that allows us to enter amount of subs,distance.batteries and will gives us a estimate of now just how much to pick up, but what to pick up?
ok im sure i got the wiring done on what i need, im going to pick up some other stuff that i know i need just dont know how much of each...so maybe you guys can help me out heres the items
0 awg fuse holder
4-8 awg fuse holder
distribution blocks
300 anl fuse
the kit i am buying comes with 1 fuse holder,2 distribution blocks and 1 300anl fuse..im sure for my application im going to need more so if you guys can give me some numbers i would greatly appreciate this...also for those who havent read or know its going to consist of 4 batteries total, 2 in the front and 2 in the back and 3 amps 2 mono's and 1 4 channel amp..so i hope this helps..thank you guys..
denalilvr
just laugh
denalilvr
illinois
patotay
