Kicker or Knukonceptz
klm is not so flexible, slightly smaller than kolossus.
thats because of the thicker outer jacket, kollusus is the only way to go for knu //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Either kicker or knu's kolossus should suit you fine.
Kicker kit comes with two dblocks and 4 gauge for multiple amps. The klm kit is just 1/0 with no dblocks for multi amps keep that in mind if your installing multiple amps.
that KLM wire kind of stinks... but it is pretty cheap.
it's not a copper wire.. it's copper clad aluminum.. and you cant really bend that crap. i have it in my car and i had to buy a few feet of different 1/0 because i couldnt bend the 1/0 like i needed it to.
dammn copper went threw the roof //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif and its still unstable //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif price per ft Knu Kollusus FTW //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I would get the Kicker over the KLM but I would get the Kolossus over the Kicker. I have both sitting in front of me. The Kicker has a little more flexibility but the Knu wire has a much better outer jacket. The Kicker outer jacket is very soft and seems like it could easily get cuts or tears in it unlike the Knu outer jacket. I can cut into the Kicker outer jacket w/ my finger nail but not the Knu. Maybe I just worry more than others about shorts and fires but I would hate to fry my amps.
i used kicker 1/0 for my car an i loved the flexibility. used knu 1/0 for the big 3 and it wasnt very flexible.. the kicker also was thicker.
The only reason the Kicker looks thicker is because of that funky rope lay they use. If you look at both Knu and Kicker side by side, the Kicker wire has gaps in between each rope lay that you can easily see and the Knu wire does not, there for making it look smaller.
from that pic the kicker actually looks a lil bigger than the knu collosus
Look at my second post up. I give my opinion why it looks bigger. If you have both in front of you, it is easy to see.
It's just like actual rope. Some rope has that thick multiple strand twist to it and some does not.
UMGixxer
UMGixxer
Jackson, TN
QtrHorse
